Temp gauge and fans not working
Old Sep 11, 2017 | 07:01 PM
Dalegreb89's Avatar
So I just bought an 89 iroc z, 5 speed 350 TPI and when I bought it, the guy told me the temp gauge didn't work and it needs new fans. Well I looked where the temperature sensor was on the passenger side of the block and where the cooling fan sensor was on the drivers side head and niether of the sensors have wires going to them. I found the wire that goes to the temperature sensor but I cannot find the wire that goes to the cooling fan sensor. Can anyone explain to me or take a picture of where this wiring is coming from??
Old Sep 11, 2017 | 09:12 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Temp gauge and fans not working
First off, the sender on the driver side is what works the temp gauge. The passenger side one is the fan switch that sends a ground via that green with white stripe wire to the fan relay actuating the passenger side fan. The driver side fan is run by the computer from info it gets from the CTS. Go to the maroon bar up the page and click on HOW-TOS. Then look under electrical and find the article on fans. It is informative and may help. Happy hunting
Old Sep 12, 2017 | 09:26 AM
Dalegreb89's Avatar
Alright, well I saw that 1 fan spins all the time even when the motor is off but the key is on so I will see which fan that is..and I'll look at the how tos....thank you
Old Sep 12, 2017 | 08:21 PM
Dalegreb89's Avatar
This is the sensor that goes to the gauge but I cannot find the wire that goes to it. Can anyone explain to me or show me where this wire comes from?
