A/C Vacuum Issue (Not the Switch)
Old Mar 2, 2021 | 07:07 PM
REAPER85Z28's Avatar
My vents are stuck on defrost. I’ve used a vacuum pump and found that connected to the hardline in the engine bay it will hold vacuum if the vent setting is off, but as soon as I move the switch to Max is loses vacuum. I’ve pulled the vacuum switch to check for the common problem of it being loose and it’s fine. Doesn’t seem to be leaking from the switch. Where else should I be looking?
Old Mar 3, 2021 | 01:20 PM
Re: A/C Vacuum Issue (Not the Switch)
Probably the vacuum motor (diaphragm) for that function.
James Sutton
Mar 2, 2015 07:32 AM
82RZ
Interior Parts Wanted
May 18, 2013 04:26 AM
Eclipsegs621
Nov 3, 2011 01:12 PM
GOTMYZ
Nov 28, 2005 10:01 PM
Scott_92RS
Feb 10, 2004 02:00 PM
