Heater Valve Vacuum Line
Old Jan 18, 2022 | 09:01 PM
Ccoe1's Avatar
Car: '88 Iroc
Engine: 5.0L TPI
Transmission: Borg Warner WC 5 Speed
Axle/Gears: 10 Bolt, 7.625" 3.08
The small hard plastic vacuum line attached to the heater control valve, I'm assuming that runs to the controls inside the car. It is broken in the engine bay. Is there a way to repair that line or do I have to run a new one?
Old Jan 19, 2022 | 08:40 AM
Re: Heater Valve Vacuum Line
Easiest way to repair it is, cut out the broken section, and replace that with rubber hose.
Old Jan 19, 2022 | 04:03 PM
Ccoe1's Avatar
Car: '88 Iroc
Engine: 5.0L TPI
Thanks sofa,
thats a lot better then running a new line through the fire wall.
someone972
Sep 2, 2014 11:52 PM
TheExaminer
Apr 15, 2014 08:00 PM
midnit
Feb 25, 2010 07:16 AM
north_oakland
Feb 4, 2009 08:55 PM
