Temp Gauge Not fully working?
Old Feb 9, 2022 | 11:18 AM
MonkeyDunkey's Avatar
Car: 1991 Camaro Z28
Engine: 5.0 TPI
Transmission: 700r
Hey, Guys I just got my very first car last Sunday, it's a 1991 Camaro z28. I had the car running for a bit and I noticed that Temperature Gauge was going up very very slowly almost not noticeable. Do you guys have any suggestions on a fix?
Old Feb 10, 2022 | 10:21 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
Re: Temp Gauge Not fully working?
Could be the temp sending unit failing, or temp gauge is failing. Not likely the gauge but rather the sending unit
Old Feb 10, 2022 | 01:05 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
could be your thermostat is stuck open
One way to tell is once its hot....shut it down. Wait a min or tw then restart it ansd see how fast the gauge goes up.
If its fast then I'm guessing yor thermostat is open or missing
If its slow, it could be the gauge or sender... (the engine wil lstil lbe hot thus eliminating the posssibility of long engine heat up)
Old Feb 11, 2022 | 07:32 AM
Whup out yer handy-dandy temp gun such as this https://www.lowes.com/pd/IDEAL-ID-SG...B&gclsrc=aw.ds and see whether it's telling the truth or not.
Not much point in working on the gauge if the problem lies elsewhere.
Old Feb 11, 2022 | 01:49 PM
72buickgs's Avatar
Car: 1984 Trans AM
I have one of those temperature guns & have used it several times to check temp at the thermostat.
blaze2fury
Jan 3, 2022 08:17 AM
DirtShaman
Oct 9, 2016 03:38 PM
