1987 Camaro Iroc Z 5.o TPI cooling issue
Old Jun 23, 2023 | 12:37 AM
Papa T'S Iroc Z's Avatar
First off thank you for taking the time to read and respond. I have a 1987 Camaro Iroc Z 5..0 TPI that runs hot. I have replaced the Water pump and thermostat,185 degrees, and dual fans with LS1 fans. I have replaced the gauges with Equus 8000 Series Gauges E8200. I connected the temp gauge to the driver's side of the engine. The gauge shows an average operating temp 240 degrees. My Radiator cap read 220 degrees. Is it normal for the gauge switch at the head on the driver's side to read hotter? Should I relocate the probe for the temp gauge to the thermostat housing? I did notice that when the coolant fan kicked in, it had low RPM. Is that normal? When I turn on the AC, that second fan also runs slower. Maybe that is my issue. Did the Camaros have a high and low-speed fan? If so, how do I fix the problem?
Old Jun 23, 2023 | 07:00 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: 1987 Camaro Iroc Z 5.o TPI cooling issue
These cars ran hot intentionally from GM. It helped with emissions. I do not believe any 3rd gen fan was variable speed. What are your temps when cruising down the road with steady airflow through the nose?
Old Jun 23, 2023 | 01:19 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
This won't help when the car is stationary, but is the air deflector under the radiator support present?
jsanders
Sep 5, 2014 06:05 PM
MuncherRS
Nov 30, 2011 04:52 PM
dep92RS
Feb 15, 2009 03:04 PM
Erin91RS
Aug 3, 2003 06:41 PM
89formula35O
Jun 26, 2003 09:43 AM
