A/C shrader valve
Old Sep 3, 2025 | 06:08 AM
BBCSwap's Avatar
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
A/C shrader valve
A/C schrader valve high pressure leaks. Are they different then what is in a tire valve? They seem pricy but what are you going to do. Opinions?
https://www.autozone.com/cooling-hea...schrader+valve
Old Sep 3, 2025 | 07:05 AM
ratfink6923's Avatar
Car: 15 Ram, 88 IROC, 92 RS
Engine: 5.0
Axle/Gears: 3.42 (4th Gen)
Re: A/C shrader valve
The seal surface is supposedly a different material. Are you still running R12?
Old Sep 3, 2025 | 07:11 AM
BBCSwap's Avatar
Nope. 134.
Old Sep 3, 2025 | 07:18 AM
Engine: 5.0
Cheap enough experiment to run, then.
Old Sep 3, 2025 | 03:01 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
I replaced one in older truck with standard tire valve Schrader. Still working fine a decade or more later.
Old Sep 3, 2025 | 05:51 PM
BBCSwap's Avatar
Good to know. Thank you.
Denis.V
Brakes
May 24, 2023 08:01 PM
