swap from 2.8 to 5.7, why does my ALDL conector not work??
Car: 92 Camaro RS
Axle/Gears: 3.73 Truetrac
Are the pins going into the ecm different or something, everything elce in the cockpit works fine, I don't get it, it worked before the swap. Please help.
-Shaun
-Shaun
Car: 78 Regal
Engine: 82 FBod LG4 305, 730 ECM
Transmission: M20
Axle/Gears: 4.10
I don't know what harness you are using but on the old aldl they used to put the data lines on E and the new ones are on M.
Car: 92 Camaro RS
well the engine harness is out of a 90 305 tbi and the dash harness is original to my car, an 89 v6, everything elce works, the light works, matter of fact it comes on every first mile of driveing because no VSS is hooked up. The only thing in the car that is sort of vital that dont work, well besides the speedo the wipers and the heat is the ALDL and I wanted to hook that up to winALDL. Any sugestions at all?
1992 Trans Am
Aug 8, 2015 08:16 PM
