Some plugs @ rich condition can ECM fix
Old Aug 10, 2002 | 10:58 PM
CHEVYTOWN's Avatar
Sup y'all....
I need some help man.
3 out of 6 plugs are pretty dark(rich). No tan color in sight. The other three are tan/white. They seem ok. Is it possible for the ECM to read those three individual cylinder's firings respectively and correct the situation. Or can a tuner run it on WINaldl and the like and fix those respective firings?
Thanks for the help bro's...CHEVYTOWN
Howell TBI universal kit 560 cfm 87-91 unit on a 250 cid L6
Old Aug 11, 2002 | 08:50 AM
hectorsn's Avatar
Car: 78 Regal
Engine: 82 FBod LG4 305, 730 ECM
Transmission: M20
Axle/Gears: 4.10
Is it a dual plane intake? Maybe an injector is leaking and soaking those three cylinders. If it's a single plane, I would think it's a mechanical problem other than an injector. Either way I don't think you can have control of individual injectors with that system.
Old Aug 11, 2002 | 03:11 PM
CHEVYTOWN's Avatar
It's a new kit from Howell. So I'll probably guess and say that the prom has to be adjusted? And ya bro, the 3 are gunked. Can a fuel injection shop fix the problem or is it best to send it back to Howell. Only thing is, 2 weeks out of a ride is pretty tough here in Los Angeles.....
The manifold is a Clifford 4 barrel.
THANKS HOMETOWN, CHEVYTOWN
Jae992
Aug 27, 2015 09:07 AM
ezobens
Aug 19, 2015 10:29 PM
jackhammer
Aug 15, 2015 10:04 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
marcusaw
Aug 10, 2015 08:13 AM
