Stock TPI ECM Knock parameter ?'s
I'm puting a set of aluminum vette heads on my L98. They've been decked and my compression is going to be around 10.1:1. My question is does the stock ecm detect knock and adjust timing/ fuel to compensate for the detonation?
Car: An Ol Buick
Engine: Vsick
The problem is that it overcompensates to be sure to keep the motor out of detonation. So if you want the best in performance you need to get a ship correct for your combination, or just settle for close enough.
Sanjay
Aug 12, 2015 03:41 PM
