speed limiter??
Old Feb 9, 2003 | 10:24 PM
Crisis's Avatar
speed limiter??
Why does my speed limiter kick in at 120-125mph and change for a sec to 4th gear. when the speeds back to 115mph it lets the engine pull again to 120-125mph in third gear.. weird?? is this normal??
Old Feb 11, 2003 | 03:25 AM
Crisis's Avatar
come on guys... you must of hit the limiter some time??? is my ecu wierd in this sence or is this normal...
I olso got a ses light yesterday while cruising on the highway.. i stoped the car and tryed to pull the error code but there weren't any and i haven't seen the ses light since... wierd...
Old Feb 11, 2003 | 04:51 PM
j91z28d1's Avatar
my 91 z28 had a speed fuel cut but mine was at 106 its in the chip some where. i got a new stock one out of a friends car when he got a aftermarket one. has somethimg to do with what tires came on your car. if they were z rated you didn't get it
Old Mar 1, 2003 | 05:00 PM
transam421's Avatar
It was actually if it had the 140mph-Firebird or the 145mph-Camaro Speedometer installed at the factory. The Speedo seems to be the the determining factor. I know that the vast majority that had the speedo came with the z-rated rubber, but not all. The speedo was an option and the z-rated tires were also an option.
Old Mar 2, 2003 | 10:06 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: speed limiter??
The MPH cut offs use a cut off speed and then a resume speed.
So there might be a 1-7 MPH area where the engine is *off*.
Depends on the tire option of what the car was originally equipped with. They didn't want you running at 140 with a tire rated to 85.
RedLeader289
Sep 23, 2015 06:50 AM
adelane
Sep 9, 2015 08:51 PM
SG91camaro
Sep 5, 2015 10:27 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
