Bad ECM?
Old Mar 10, 2003 | 02:05 PM
Jurrel's Avatar
Car: 1984 Firebird
Engine: 2.8 Carburated
Transmission: T5 Manual
Bad ECM?
To start this is a 1984 Carb'd 2.8L V6 Firebird.
The original computer I have NOT been able to get to show any codes at all and the car has been running quite rough even after a full tune up. On a whim I pulled another ECM from a 84 carb'd bird at a local junkyard, That one showed code 54, bad mixture control solenoid...and indeed it was bad. However after replacing the Solenoid, the computer is still showing error 54, even after pulling the ECM fuse for the night.
Is there any way to test the ECM's and verify if either of them is working???
Or should I try for a 3rd ECM and hope for the best?
Old Mar 10, 2003 | 09:24 PM
RdDgg71's Avatar
you did reset the computer after each time you started somthing
Old Mar 10, 2003 | 10:54 PM
Jurrel's Avatar
Car: 1984 Firebird
Ayep of course I did.
Reset by removing the ECM fuse for approx one minute each time.
Old Mar 10, 2003 | 10:57 PM
RdDgg71's Avatar
no you need to disconnect the battery to clear the computer try that and see what happends
Old Mar 11, 2003 | 12:07 AM
Jurrel's Avatar
Car: 1984 Firebird
Well I have Also had the ECM completly disconnected from the car, swapping them back and forth as I have two. That would be the same as disconnecting the battery, correct?
skeltor
Feb 2, 2016 10:37 AM
88rscamar0
Sep 23, 2015 09:08 PM
Billy Decker
Sep 4, 2015 03:46 PM
willyjoejr
Sep 3, 2015 09:26 AM
RyanJB
Sep 2, 2015 01:27 PM
