help!!!
Old Apr 15, 2003 | 10:31 PM
SlowMaro's Avatar
help!!!
so here goes, ....car will run FINE, all day long, until i shut it off, and crank it again, after tha it runs ROUGH as hell and just dies.....once again, ..itll fire right u and run fine if the car is cold.....but after its hot, and i start it again, ..sputter sputter .....glug....dies....any clue anyone??
Old Apr 18, 2003 | 06:18 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: help!!!
Can you post your VE and timing tables.
Was it fine before the cam swap.
Betcha Need4speed has the answer.
Old Apr 18, 2003 | 06:49 PM
SlowMaro's Avatar
yeah it was fine before the swap...i dont thinkthe cam itself is causing this.....timing is set at 1 degree advanced...--was running a lil lopey at 0-- define VE heh....by the way, ..if anyone needs to know ive replaced the ECM, IAC, MAP,egr solenoid, engine temp sensor , o2 sensor, cap, dist, wires, plugs, coil, ignition module,rotor, ...checked all hoses and wire connections....
