727 harness pin part numbers
Old Aug 16, 2003 | 06:18 PM
subsonic9's Avatar
Car: 86 IROC
Transmission: WC T5
Does anyone have the GM part #s for the pins that are used on the 727 plugs.
Old Aug 17, 2003 | 08:50 PM
funstick's Avatar
if you find them please toss me an email with that p# also if you find the connector for the ecm p# id like that even more.
i think some of the packard wire stuff over at way-tekwire.com might work. i just splice the wiring and reuse the pins with a 10-12 inch pigtial cut off of a lumina or something similar.
Old Aug 29, 2003 | 08:06 PM
Captain C's Avatar
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
Probably the same as for the 730, just take it to the local GM dealer and they can look them up for you on their computer. I've had to do that several times when I needed to replace a pigtail....
Old Aug 30, 2003 | 01:04 PM
subsonic9's Avatar
Car: 86 IROC
Transmission: WC T5
They are different. I went to the local dealership and think I have the right ones. I haven't posted the part #s yet because I want to make sure they are the ones. When I receive them and verify they are correct I'll post the part #s.
Old Sep 9, 2003 | 07:45 PM
subsonic9's Avatar
Car: 86 IROC
Transmission: WC T5
They came in and are correct. The GM part # 12066132
They come in packages of 10
Old Jul 26, 2004 | 01:12 PM
poncho@home's Avatar
Car: 2004 BMW 330Cic
Engine: 3.0
Transmission: 6 speed
would these be the same for the '165 ECU?
Old Jul 26, 2004 | 09:16 PM
subsonic9's Avatar
Car: 86 IROC
Transmission: WC T5
Sorry They are not. I will have to look to find the correct part#.
1992 Trans Am
May 10, 2023 07:19 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
355sbcTPI
Aug 19, 2015 04:38 PM
TA8487
Aug 16, 2015 12:21 PM
armybyrd
Aug 10, 2015 09:23 PM
