new here need some help mpfi
Old Sep 5, 2003 | 07:59 PM
tuknrm's Avatar
im going to try to make my own fuel injection. with camaro tpi computer. speed density system. im going to use a 1000 cfm throttlebody, on a single plane intake. i have a custm grind cam that puts out about 15in vacuum. will the tpi computer like this or will i have to get a different map or something. i will be tuning the computer but i didnt know if the vacuum would totally screw it up. also what injectors should i go with. i have 95 to 100% ve between 2500 and 7000, 10.5:1 comp, aluminum heads p&pd, i will also be adding nitrous at a later date. this will mostly run at strip. but i want it to idle better. anyone have a similar combonation
Old Sep 6, 2003 | 08:30 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: new here need some help mpfi
You're going to have to do some editing to the prom for the ecm to run that engine.
You need to visit and read thru the Prom Board for a while.
Old Sep 6, 2003 | 11:27 PM
tuknrm's Avatar
thanks... ive been looking for a base if anyone has one to a similar engine combination, for me to work with from there.
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
Springster
Sep 13, 2015 01:38 PM
87_Camaro
Oct 4, 2001 01:31 PM
87_Camaro
Aug 29, 2001 04:49 AM
Mikes86SC
Jan 24, 2001 11:43 AM
