AKFN? memcal help pease!
Old Sep 14, 2003 | 01:09 PM
88TAJeff's Avatar
Car: 88 T/A
I pulled my memcal to replace the chip that was burned for me, and it doesn't look like one I've seen before. The prom is labelled 'AKFN'. The memcal is 2 chips (1- 14 pin & 1-16 pin), and the prom all on one giant chip socket. It looks like I can just remove the prom and insert the new one. I don't want to screw up something though. Does this look right?
Old Sep 14, 2003 | 01:27 PM
88TAJeff's Avatar
Car: 88 T/A
Upon further inspection it appears it won't be that easy. Seems that the chip is soldered to the holder somehow, but I can't get at the connections at all. What to do?
Old Sep 14, 2003 | 05:01 PM
Mechanic's Avatar
You can get to the connections more easily if you remove the bikini.
Really tho, I usually end up clipping the legs of the eprom with some very small wire cutters or nail clippers, then carefully heat the socket and pull the remaining portion of the leg out with tweasers. You may want to get a copy of the existing binary from the memcal before you attempt this by using an memcal to burner adapter, and if you get a chance please email a copy of it to me at gmpcm@comcast.net as it is not in my download database yet.
Old Sep 14, 2003 | 05:04 PM
88TAJeff's Avatar
Car: 88 T/A
Thanks Mech, but I used some solder wick and she came out like nothin'.
Old Sep 14, 2003 | 05:05 PM
Mechanic's Avatar
Did you happen to get a copy of the binary?
This solder wick thing sounds like a nice deal, I am a novice with an iron (ie. dangerous). I may have to give this a try next time...
Old Sep 14, 2003 | 05:36 PM
gregger2k's Avatar
Mechanic,
I sent a copy your way.
Greg...
Old Sep 14, 2003 | 06:14 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
How did you use solder wick to get a bikini off?.
Ugh, on second thought I don't want to know, LOL.
88SS6SPEED
Nov 11, 2015 07:05 AM
lethaldomestics
Sep 21, 2015 01:18 PM
RyanJB
Sep 2, 2015 01:27 PM
Keith5
Aug 27, 2015 04:37 PM
