Where to start need to make a stand alone harness
Old Nov 10, 2003 | 11:54 PM
camarochic's Avatar
Car: 86 Camaro Iroc-z, 86 Corvette
Engine: 350 TPI Camaro, 350 tpi Corvette
any advice please help:lala: :lala: :lala:
Old Nov 11, 2003 | 09:47 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Where to start need to make a stand alone harness
If you can get the factory wiring diagrams for the same year harness you will be set. That is the best way to go. If not, maybe a Chiltons or such at the local library will help.
As you strip down the harness you may/will find wires that are not part of the EFI. GM always seems to tuck a few in there for the alternator or a temperature sender or some such thing. So don't be surprised to find 'extras'.
It can be helpful to put masking tape flags on connectors and label them as you figure out what each is for.
RBob.
Old Nov 11, 2003 | 05:09 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Camarochic, forgot the diy-efi site was even back up. Go here:
ftp://ftp.diy-efi.org/pub/gmecm/manuals/1227165/
And at the bottom are a series of links for the wiring/pin-outs for the EFI system. Good stuff.
RBob.
Old Nov 11, 2003 | 08:35 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Also, what "stand alone" do you want to make?
For SD setups, you can salvage many harnesses out of other models and make it work with minor modifications. The easiest "fix" is to make the harness from a 90-92 V6 F-body work on a 90-92 V8 F-body with only minor changes.
But get those diagrams like RBob said, and then you can see what you need and what modifications you'll need to make it work.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
TheExaminer
Aug 26, 2015 04:59 PM
jharrison5
Aug 19, 2015 05:53 PM
