i have a frankenstein tpi system - NEED HELP!
Old Nov 28, 2003 | 11:06 PM
stevedave454's Avatar
Car: 91 S10
ok, i bought an 88 5.7 mas air tpi system off ebay, with harness, but no ecm, then i bought an 88 5.7 mas air ecm (i dont know serial #, as i did not ask, and have not actually recieved it yet) first question should i be ok so far? or do i have to have a specific serial #? second question i am putting this on a 350 in an S10, the chip in the ecm is for auto, i plan to use a t-5, i need to change chip/memcal correct? i have NO burnin skills or equipment, and although i want to learn, im not ready to buy all the equipment right now, so would i be best off just buying a stock memcal for a manual? and does it have to be from an 88 5.7 mas air system?
Old Nov 29, 2003 | 08:13 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: i have a frankenstein tpi system - NEED HELP!
Yep, so far, so good. The ECM when it comes should have service number 1227165 or 16198259 on it. Using an auto MEMCAL on a stick car typically works. Most important is to make sure all sensors are hoooked up as the factory intended, including the VSS.
If you do end up buying a MEMCAL get one that as closely as possible matches the vehicle year & options.
RBob.
Old Nov 30, 2003 | 09:29 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
Re: Re: i have a frankenstein tpi system - NEED HELP!
RBob.
It worked in my case for like a month sort of. the car idled crappy, was hard to start , and when you let off the accelerator in any gear the car would buck. It'll work, but you won't be happy with it probably.
Old Dec 20, 2003 | 02:20 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
You may get a trans related trouble code running an auto chip in a stick car. You also may not. My '86 threw one when I went from a 700R4 to a T56.
TPIS should be able to burn you a chip from a simple phone conversation, as should a lot of other shops. I got mine from TPIS and the car runs great.
gta90
Sep 15, 2015 04:00 PM
Keith5
Aug 27, 2015 04:37 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
