used dfi
Old Dec 15, 2003 | 06:39 PM
emtcee's Avatar
Car: 67 camaro
Engine: 383 accel dfi
Transmission: t56
used dfi
i bought an accell dfi unit used and was would like the harness and calmap serial interface cable checked out to see if they are in working order.does anyone know where i can get that done?
Old Dec 16, 2003 | 04:59 AM
FAST LiFE's Avatar
You can send it back to Mr. Gasket/Accel. They can still service the older DFI boxes. Hope this helps.
Old Dec 16, 2003 | 04:47 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: used dfi
Power it up and edit the ecm file.
Then save, then close everything out.
Then reboot, and see if the edited change is still there.
If you have the car running edit the timing table to say 25d, and then rev the engine to make sure it's at 25, then edit it to say 30d and see if the timing changes correctly.
Old Dec 16, 2003 | 05:12 PM
emtcee's Avatar
Car: 67 camaro
Transmission: t56
i don't even have the motor built yet.can i hook i up to a battery and a laptop and see if i works?also does anyone know what wires on the map sensor harness go on the map connector?mine are cut.any help would be appreciated...:
efiguy
Sep 27, 2015 01:30 PM
e3pres
Sep 9, 2015 01:51 PM
marcusaw
Aug 10, 2015 08:13 AM
manuel
Aug 19, 2001 10:29 AM
