log data=mpg guage
Old Jan 9, 2004 | 01:23 PM
11sORbust's Avatar
log data=mpg guage
Is the a way to use datamaster or log data to calculate aprox miles per gallon?
Old Jan 11, 2004 | 12:01 AM
11sORbust's Avatar
uhhh.... you know datamaster has fuel total....anyone....???
Old Jan 12, 2004 | 08:36 PM
rkadair's Avatar
Car: 88 Jimmy
Engine: 350 Vortec TPI
I was wondering what that fuel total was for
Robert
Old Jan 13, 2004 | 12:19 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Havnt used datamaster but i would assume that it just adds up the pulse widths and does some calculations to determine the total ammount of fuel flow. If the injector constant and the fuel pressure are known accuratly, i woudl assume that its probably reasonably close to the ammount of fuel used. Youd then take the fuel total and divide by miles driven to get the mpg. Ive done a similar thing with my winaldl data logs since the odometer and the trip odometer are busted (thanks to a fit of rage on my part).
Old Jan 23, 2004 | 01:01 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
the only problem is that if 1 injector is clogged or your voltage fluctuates even a little it throws the whole calculation into chaos.
for instance at 13V your injectors open slower (and therefore flow less fuel over time) than at 14V. so at idle you may encounter really high Pulse Width readings yet only be getting a little fuel because of the voltage drop from sitting at a low rpm.
happens to me all the time. Best way to average fuel economy is to Top it off, drive it, then top it off again and check your miles travelled vs fuel pumped in.
sheachopper
Jul 31, 2019 11:27 AM
bjpotter
Oct 4, 2015 07:48 PM
