How to go back to Injection?
Old Mar 5, 2004 | 12:49 AM
IROCFAST's Avatar
Hey fella's, about 3 years ago, I went from TPI to carb and now am wanting something a little more street friendly. I was wondering if I could use any TPI ECM as long as I get a custom chip? Also, I am going to use a painless wiring harness to take some of the headache out of it. The car has TFS heads with 10.5:1 compression, it will have a larger hyd roller cam 234/244 @ .50 on a 112 lsa and I will be using a Stealth Ram setup. I would like your inputs on which ECM would be the best, MAF or SD (730 or 727 etc)? I may go with a slightly smaller cam but am unsure right now. My car is an 89 originally a 5.7 A4 car, now it has a 5spd though. Any help would be great.
Thanks,
Brit
Old Mar 5, 2004 | 10:30 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: How to go back to Injection?
SD,
and you might as well resolve yourself into getting into doing your own chips. Each engine is just enough diffferent your not going to find any one size fits all generic chip to work correctly.
Old Mar 6, 2004 | 10:56 AM
IROCFAST's Avatar
That is my next question, is there a write up somewhere that can teach me how to get started? Will SD handle that much cam?
Thanks,
Brit
Old Mar 7, 2004 | 01:04 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Go over to the DIY-Prom board and see the stickies. After that look and search around some. Jsut about everything imaginable has been gone over.
midge54
Dec 27, 2019 04:14 PM
Fast355
Dec 2, 2016 06:33 PM
toronto formula
Nov 10, 2015 06:17 AM
86Base
Aug 13, 2015 05:06 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
