Solid flat cam in a 85 vette?
Old Apr 30, 2004 | 12:26 PM
compuvette's Avatar
Car: 84 Vette
Engine: CFI 350 with mods.....
Transmission: A4
Got an extra original LT1 solid cam laying around and wondered how the knock sensor would handle that. I realize I would have to program the ecm to handle the bigger cam but I can handle that. Will it live or will the knock sensor freak out? Go with a roller sensor maybe? Thanks!
Old May 2, 2004 | 07:26 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Solid flat cam in a 85 vette?
I have no idea but if you use the solid I would like to hear of how it works out.
If the knock sensor does have a problem with it the knock retard can be disabled in the calibration tables. The BBC with the '7747 didnn't run a knock system at all. It would come down to preference of whether you want an ESC system or not.
RBob.
Old May 3, 2004 | 10:28 AM
compuvette's Avatar
Car: 84 Vette
Transmission: A4
Gotta see if I get the '85 vette yet or not. If I do I am seriously kicking around the solid LT1 cam as it would be different. Don't know how well it would perform with a TPI manifold but it would be kinda cool....... Planning on running roller rockers so I don't have to adjust the lifters quite so often.
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
Jorlain
Oct 8, 2015 01:57 AM
Stryker412
Sep 7, 2015 09:11 AM
TheExaminer
Sep 6, 2015 11:40 PM
greenyone
Sep 2, 2015 03:39 PM
