Does the ecm rely on tach reading at all?
Old Aug 19, 2004 | 08:38 PM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
Problem is, I am going to be putting in a 4thgen dash and I have an LS1 cluster. The LS1 tach is not going to read correctly when I put it in my car until I get a Dakota box which wont be for awhile.
So my questions are
1)Does the ecm rely on the tach for anything or the tach the ecm?
2) Will it hurt the LS1 tach if it is bouncing all around all the time until I get the Dakota box?
Old Aug 20, 2004 | 06:36 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Does the ecm rely on tach reading at all?
So my questions are
Not the tach reading or tach connection from the coil.
The ECM uses reference pulses directly from the distributor ignition module. This signal is passed on to the ECM via the 4-pin connector on the distributor.
RBob.
Old Aug 20, 2004 | 05:45 PM
Transmission: 4L60e
Axle/Gears: 9 bolt
allright cool. So that tach not working wont screw with the ecm. But what about the 4thgen tach itself? Will it get damaged at all driving it like that for awile?
mddaniel
Sep 8, 2015 05:16 PM
RyanJB
Sep 2, 2015 01:27 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
