Commander 950 Question
I did a search and found lots of useful info. but never really found what I needed. If I want to use the Commander 950 on my 86 Camaro w/ the stock TPI setup, how exactly do I wire it in? Do I need to keep the stock ECM or can I do away w/ it completely? Also, do I need to buy a harness, do I just repin the stock harness?
Depends on you skill in wiring up electronics. I found it easy wiring up a tbi harnes for the stealth ram. All i have is a bit of difficulty with the injectors (you have a stock harness with provission the 8 injectors, mine had 2).
I would repin.
Oh and you need a map sensor. IAT might need to be changed also.
I would repin.
