Question about 870 ECM's
Is it possible in the tuning to switch to batch fire instead of a CS setup?
Is it possible to change the injector constant?
I think my injector's are leaking b/c it's flooding when I leave it sitting which makes for a hard start everytime I kill it. I have a spare set of LT1 24#'s I'd like to put in, but I dont' know if I can just throw them in without any ECM modification which I guess will be my 3rd question although it may not belong in this forum. Can I just throw them in without any problems?
Thanks in advance for any help.
Car: check
Engine: check
Transmission: check
To get rid of the cold start injector you will need to upgrade to a '165 ECM and use MY '89 code ($6E).
There probably is an injector constant in the current code. However, I can't guarantee it. I am not familiar with the '870 code at all.
Going from 22#'s (350ci engine, correct?) to 24#'s isn't too big of a jump. The BLM will correct for it. Although it will be richer under WOT and open loop conditions.
RBob.
RBob.
Actually I read last night that the 85's came with 24's stock, so I may be good in that respect.
Thanks for your help.
So there isn't a batch fire operation possible under the 870?
Car: check
Engine: check
Transmission: check
It wasn't until the '89 code that GM added cold enrichment to the ECM. TPI is batch fire no matter if a CS injector was used or not. Batch fire just means that all 8 injectors fire at the same time (in a batch).
RBob.
