Aldl cable help, new to the scene
Old Feb 21, 2005 | 05:08 PM
bad_bo_ti's Avatar
Car: 93 chevy 4x4
Engine: 5.7 350
Transmission: 4l60e
hello, first off let me say that alot of people have reffered me to this board for help with fuel injection and aldl help. i own a 93 chevy 4x4 truck with a 5.7 automatic. i just purchased an aldl cable and cant figure what pin needs to go where. i have 2 pins, a red wire and black wire. i have a 12 pin connector under my dash. i have the following pins available on the truck, A B D G H and M everything i have read so far states i need to plug into A and E i dont have an E. what i am needing help with is which terminals do i plug into and do i need to add anything else to the cable. if for some reason i posted this in the wrong form i apologize. please help me thanks chris.
Old Feb 22, 2005 | 08:08 PM
Siggy's Avatar
Car: 1988 Camaro IROC LB9 F
Engine: 305 HO EFI
Transmission: TH700R4
Axle/Gears: GU5 LS 3.23
ALDL connections
Try this site for info, I'm not expert on your car but this site helped me with my 88 IROC.
http://www.techedge.com.au/vehicle/aldl8192/8192hw.htm
Old Feb 23, 2005 | 04:25 PM
bad_bo_ti's Avatar
Car: 93 chevy 4x4
Engine: 5.7 350
Transmission: 4l60e
thanks for the help, i think i have figured out my truck is a 8192 baud rate so i cant use winaldl i have tried finding a scanner for the 8192 but havent had succes in finding one, can some one direct me to a good one, thanks, chris
Old Feb 23, 2005 | 06:24 PM
bad_bo_ti's Avatar
Car: 93 chevy 4x4
Engine: 5.7 350
Transmission: 4l60e
ok i downloaded datamaster and got it on my laptop, went outside plug in to the truck and nothing, i put the resister in from a-b and still nothing, now i am thinking i got the wrong cable, i got it from aldlcable.com if any one wants to help me out. so if i got the wrong cable what do i need to add to mine to make it work. thanks, chris
Old Feb 23, 2005 | 09:30 PM
bry92firebird's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
Transmission: 5 Speed Manual
Try TunerProRT. Get the data stream for your vehicle. I use it on my 92 'bird.
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
