Fuel injector drivers
Old Apr 11, 2005 | 02:21 PM
pellmanm's Avatar
Car: 1989 GTA
Engine: 383 Fuel Injected
Transmission: Pro-Street 700-R4 by Pro-built
Axle/Gears: Moser 12 bolt w/posi
If my fuel injector drivers are bad is there a way to test them. If they are bad how can i get them repaired and who can do it and for how much? Thanks.
Problem: The car starts fine, idles fine, after running for a minute or so it runs rought at higher rpms and if it is turned off it will not restart. the #7 injector is a 3 ohms, and number #1, and #2 injectors are at 13 ohms, all the others are at 16 or 17.
I disconnected the 3 ohm injector, ran it, turned it off, but it would not restart.
Old Apr 11, 2005 | 06:50 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Since you KNOW the injectors are bad (low impedance on 3 of them, and who knows what kind of spray pattern on the rest,) replace them and then worry about the ECM.
The only way I know of to test the drivers is to use a testlight to see if there is a ground pulse signal at the ECM side of the injectors while cranking the engine. Since the engine does run, the driver can't be completely toasted, but the transistor could still be overheating.
It sounds to me like the injectors are your whole problem. Start there and see what happens.
Old Apr 11, 2005 | 08:01 PM
pellmanm's Avatar
Car: 1989 GTA
I just disconnected the 3 ohm injector and it still has the same problem, shouldn't disconnecting it remove the problem. I did jst order some ne 24 lb accel injectors.
bryan623
Mar 22, 2021 06:43 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Bryan F
Aug 18, 2015 02:28 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
