LT1 computer for TPI
Old May 24, 2005 | 09:45 PM
ManoftheHour's Avatar
since the LT1 coputer/ electronics are more easily programmed.
Is it possible to just cut the wires you dont need and use its computer tonbetter tune a car?
or is it cheaper to buy another ECM?
What ECM solutions are out there?
MTH
Old May 25, 2005 | 10:59 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
This has been talked about before a few times you need to do a
There is no easy way to run a LT1 ECM in our cars. The LT1 ECM would be looking a signal from the opti-spark distributor which is completely different signal from HEI. Unless you are really good at source code the answer is no.
Just go to the junk yard and get a 730 ECM for $30 and call it a day, and if you are not running a 730 ECM right now then there is a tech article on how to convert to it.
Old May 26, 2005 | 03:01 PM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
A few people have mounted the Opti guts inside a conventional distributor, so as to be able to use the '8051 LT1 PCM on a regular SBC.
But with an emulator, or a Prominator, a '730 is faster and easier to program, and can even be tuned on the fly, which currently isn't possible with the LT1 PCM. Plus, you don't have to worry about locking up the PCM if something goes wrong during the programming sequence, which is definitely no fun (a concern unless you're using a bench harness. And spare ECMs are cheaper, too.
midge54
Jan 29, 2017 07:00 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
Thirim
Aug 9, 2015 06:19 PM
