Help with 89 Iroc and DFI
Old May 27, 2005 | 02:37 PM
JRS89IROCZ's Avatar
Car: 89 Iroc Z
Engine: 5.7
I have a couple of questions if anyone has time to answer them .
First I have an 89 Iroc that is all stock with an auto trans and a complete Super Ram for a BBC. I want to install this on my tpi, everything is going pretty good until I was looking at the injectors and found 4 of them has RIN-1 9320 and the other 4 has RIN-1 9308 is this ok?The ECM I have has 015013 on it with part No. 74106 and Serial No. 59068, I know this is configured for a big block because i got 3 fuel maps from White Bros. Marine in 2001,one is for a 454 SS the other is for a 396 and the last is for a 468 set up for the strip.I have the Cal map software and connector, where can I get a base fuel map for a 350? I am in the process of building a 383 but will be running all factory except exhaust ,headers, MSD Pro billet distributor, Msd 6AL ignition box and the fuel pump that came with the DFI kit with all 6AN braided fuel lines.I have already removed the smog pump and EGR and gasket matched the intakeand runners. There is no emissions testing where I live so that is not a problem. Sorry for the long read
Jr
BAMiller
Sep 14, 2015 06:38 PM
angel2794
Sep 8, 2015 06:22 PM
g.l.mos
Aug 22, 2015 12:02 AM
mustangman65_79
Aug 11, 2015 03:17 PM
marcusaw
Aug 10, 2015 08:13 AM
