gen7 log
Old Jan 5, 2006 | 07:19 PM
emtcee's Avatar
Car: 67 camaro
Engine: 383 accel dfi
Transmission: t56
gen7 log
just wanted some feedback on one of my log runs...any comments or help is welcome....
mike
Old Jan 6, 2006 | 06:28 AM
aDFIguy's Avatar
Car: GTP
Engine: L67
Open up your Base VE table, press the Overlay button, and select that same log file that you posted. Then step through the file point-by-point and adjust your VE values by the amount of your O2 correction for each table value that you encountered during the run that you logged.
Old Jan 6, 2006 | 09:39 AM
emtcee's Avatar
Car: 67 camaro
Transmission: t56
thanks dfi guy...i figured thats what you do...do you think its necessary to tune on a dyno???i do have the wideband setup...right now i am primarily working on the fuel map,however i am not really sure how to tune the timing map...any info you could give would be great...
thanks,mike
Old Jan 9, 2006 | 06:37 AM
aDFIguy's Avatar
Car: GTP
Engine: L67
A dyno obviously makes tuning quicker and easier, especially on the timing side of things. You can't beat having raw numbers to compare run by run to see exactly what the changes you've made have done -- especially for timing adjustments. For a price, it can eliminate most of the unknowns involved with tuning by feel on the street. If you are new to tuning, I'd strongly suggest some dyno time until you get a feeling for exactly how changing a given tuning parameter will affect the operation of the engine. A wideband is very helpful, but remember to treat it as a tuning aid rather than a failsafe that will "protect" you from any tuning mistakes that you might make.
Old Jan 9, 2006 | 06:48 PM
emtcee's Avatar
Car: 67 camaro
Transmission: t56
thanks for the reply...just for the record i'm not relying on the wideband...i'm getting it tuned so there is only 5% correction(on the rich side)...thanks again dfi guy....
mike
Cornholio7979
Sep 20, 2018 02:31 AM
L98GTA87
Oct 19, 2015 10:43 PM
89fast5oh
Sep 27, 2015 09:04 PM
BWilcox
Sep 20, 2015 12:19 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
