749 injector firing order
Old Feb 28, 2006 | 02:42 AM
Spin City Turbo's Avatar
I am confused as to which order the ecm will trigger the injectors compared to the firing order on a 4cylinder motor. My firing order is 1-3-4-2. The stock sunbird schematic batch fires 1+2 together and 3+4 together. For my firing order1342 I wired 1+4 together and 2+3 together. How is this supposed to be wired? Should i put 1+3 together and 4+2 together so the injector is fired in advance for the next cylinder to spark?
Old Feb 28, 2006 | 06:30 PM
89C2500's Avatar
Car: 89 C2500
Engine: ZZ838, MPFI, Whipple, & 7749 ECU
Axle/Gears: 4.10
749 is not SEFI so I don't think it matters. I'm running it on a V8 with saturated injectors (high impedance) so it's wired like a Syclone/Typhoon and fires in batch mode. I believe the Turbo Sunbird wiring is for peak and hold injectors (low impedance) but still fires batch mode.
xxx3man`
Aug 28, 2015 02:21 PM
Justin92GTA
Aug 27, 2015 11:16 PM
Jae992
Aug 27, 2015 09:07 AM
86IROC112
Aug 21, 2015 07:20 PM
justin57
Aug 20, 2015 07:05 PM
