Software for an 82 CC Carb?
Old Mar 20, 2006 | 11:58 AM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Hey, I'm wondering what programs I can use for my 82 Trans Am. It has a Computer controlled Q-jet.
So far I've found AutoXray and Diacom.
AutoXray is definitly not worth the money. I'd have to spend over 400 dollars on a scanner alone. I don't need to know what my sensors are reading that bad. It would be the same cost to swap in a used TPI and use Tuner Pro.
I forgot the cost of Diacom, but I remember it was also really expensive.
Auto Tap seems to be for OBD II only.
Here's a useful site I found in the process. I'm learning quite a bit in this process.
http://www.aldlcable.com/
Old Mar 20, 2006 | 02:23 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
If you have a laptop WinALDL is a freebie that works with the CCC setups.
RBob.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
