ECM/PROM swappability questions
Old Apr 1, 2006 | 08:31 AM
codemonk84's Avatar
Car: 1999 Camaro SS
Engine: 5.7L LS1
Transmission: 6-speed
So...I found out that it's amazingly difficult to find a CJZ prom chip (mine went south it appears (Code 51...which only comes up with the old chip in). However, I did find a CJT chip in a junkyard and I'm curious how swapping those would affect things.
As far as I could tell (and please correct me if I'm wrong), the only difference between the two is one is for an automatic and the other for the 5-speed manual (same engine, 305HO right?). What else would be affected if I swapped out the chips? (I know this is probably a bad question to ask after the fact that it's currently in the car but I figured I had little to lose since I have a spare ECM :P).
I'm a bit worried though...thoughts? (Thinks so far have been running fine but I wanted to double check with you experts here since this is my first delve into the automotive repair world :P)
Both ECM's are part#: 1226455
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
