F.A.S.T
Old Jul 13, 2006 | 04:11 AM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
F.A.S.T
ok guys i wanted some input on what to do with my set up. i was looking into going with the FAST setup then i was talking to a guy who owns a shop that tunes stock ecm's and he made his own set up that uses the lt1's electronics. he said that his system is much easier to use. he says that all you need to do is put in the cam spec's and thats it. he made 425Hp on a 355 with a holley stealth ram using his setup. the cam was one size smaller than mine (sorry i dont have my cam spec's on me now). the car is a street car that will see very little track. any idea's on which set up i should go with. the nice thing with his set up over the fast is that his uses a MAF. here is a quick summary of my motor....383 holley strealth ram, 30lb injectors, 58mm tb, afr 185 heads, .510/.503 comp cam with 1.6 rockers (i think that is the lift of the cam) hooker LT's
any ideas will be great. thanks
f-bodyz28
Sep 2, 2015 05:03 PM
minigunz
Jan 18, 2013 11:15 AM
Firebirdjim
Jun 28, 2008 12:33 AM
