dfi 7 ignition problems/ crank no start
Old Aug 10, 2006 | 02:32 PM
Recaro trans am's Avatar
Car: 1985 pontiac trans am
Engine: Procharged 5.7l
Transmission: t-56
Axle/Gears: stock 9 bolt 3.71
My ignition module took a crap yesterday, now the car will not run with the system controling timming. anyone ever have this problem?
Old Aug 11, 2006 | 06:39 AM
aDFIguy's Avatar
Car: GTP
Engine: L67
Hook up your Laptop and see if you get RPM displayed on the screen while you are cranking.
If you don't see the engine speed changing while you are cranking, it's a problem with the crank signal to the DFI.
If you do see RPM, and the injectors are working, then it's a problem with the EST output signal or whatever is actually firing the coil (or the coil itself).
Caspar
Jun 19, 2016 11:19 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
Tonyy_z
Aug 12, 2015 07:20 AM
