procedure for testing for closed loop
Old Nov 24, 2006 | 12:13 AM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
I thought I had it understood the other day and jumped a&b (same pins I jump for codes) while the car was running and warmed up. The SES light gave 2 quick blinks and no more. Tried again with same results.
Was I doing it right?
The car is running super rich, hesitates from a stop until I give it more gas, turning all 6 plugs black, sucking down gas, losing fuel pressure when the pump stops priming, and I'm getting code 13 (lean o2), and I have a massive exhaust leak 10 in behind the o2 right before the cat, and a smaller header gasket leak on the bottom of the right side center tube.
If I could tell if it's going into closed loop it would give me some more to go on.
The engine is a new 3.4 with old junkyard injectors. The rest is all 89 2.8 maf stuff. I've been having this problem since I put the engine in.
Old Nov 26, 2006 | 03:20 PM
Engine: 3.4
Nevermind, jumping A&B seems to work now. Stuck in open loop.
Nick McCardle
Sep 10, 2015 08:36 PM
IROCtometal
Sep 9, 2015 10:01 AM
83 Crossfire TA
Sep 8, 2015 12:06 PM
luvofjah
Sep 3, 2015 07:08 PM
