My T-62 L-98 turbo project ...tuneing ?
Old Jan 9, 2007 | 12:21 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I have a prominator Pro chip and 165 ECM . I just bought a bigger fuel pump
Walbro GCA758-2 I am going to be running the stock 22lb injectors ( cleaned and flowmatched) . I plan on upgradeing as soon as possible but , I want to know just for boltig this kit on from BBS. Will it run ? Am I in any serious danger of melting it all down ? The wastegate has a 9 lb spring in it . So I figure I will see about 6 psi before creap. Can I possibly give this a good enough tune to run it around ? I don't care about optimal at this moment , I just don't want to blow stuff .
Any feedback would be greatly appreciated
Old Jan 9, 2007 | 02:19 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Do you have an fmu? Bigger injectors would be better if you 'really' want to drive it.
It will start and drive, but I wouldn't lay into it without a wideband.
Bring in p/e way sooner with the pe vs tps table and work on ae fueling before you 'get on it'.
I think even if the knock sensor pulls timing you could still do some damage.
Old Jan 11, 2007 | 01:54 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
thanx alot for the info . I don't have an FMU . Eventually I want a standalone unti like a FAST setup w/ bigger ( 50-60lb injectors) . So I am trying not to spend alot on another " temporary " set-up. I will try and mess with them settings you mentioned. I do at present have a autometer A/F guage on it. Will it at least be reliable enough to run around with ? Idon';t plan on tromping it ( unless the A/F guage shows a comfortable a/f ratio)
thanx agian
PS. I am runnnig the $6E mask with APYP bin ( vette bin) stock was APYS . I just did it to get rid of the limiter for now.( had no laptop at the time.)
F.I. 57 Belair
Aug 23, 2021 01:09 AM
ZZ3Astro
Aug 13, 2019 12:57 AM
Magman
Sep 13, 2015 12:14 AM
Nick McCardle
Sep 10, 2015 08:36 PM
