Scanning 4thgens?!!
Old Jan 17, 2007 | 01:02 PM
PeterFeix's Avatar
Car: Trans AM GTA 1989
Engine: 383 HSR AFR195 JRC Cam280/286
Transmission: T56 Conversion
Axle/Gears: 3.27 9bolt
Scanning 4thgens?!!
Hi!
Does anyone know how to scan a 4thgen 3.4L v6 firebird?
Its a 95' model , with 12-pin aldl port.
I have a aldl cable ( auto-xray ), but no software that knows the 4thgen.
diacom just works with 3rdgens and lt1, i think.
is there any program which contains data for 4thgen v6 with aldl??
greets & thanks in advance
alex
Old Jan 17, 2007 | 07:36 PM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
I have the Auto-Xray reader and you need a special cable. '95s had OBD2 ports but OBD1 computers. Or you take your OBD1 cable and connect it to the other port with jumper wires to the correct terminals. You just need the serial signal and a ground to read the codes.
Old Jan 17, 2007 | 08:29 PM
PeterFeix's Avatar
that 95' has definetly a 12pin obd1 port like my 88' T/A.
my cable is auto-x-ray, as I said, but the cable/com1 pc connector is custom built by a friend. works very nice with 3rdgens....
Old Jan 17, 2007 | 08:51 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
It's my understanding that the 95's will have either the 12 or 16 pin ALDL connector. Probably a mid year switch thing.
Old Jan 18, 2007 | 07:26 PM
PeterFeix's Avatar
it seams that i have the right cable, but is there any software like diacom which works properly with the L32 / 3.4L pcm ?
i tried efilive v4 ( for aldl / obd1 ) but it doesnt work with my cable ;(
1992Z28!
Nov 19, 2015 07:33 AM
RGB2015
Sep 20, 2015 09:26 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
dhirocz
Jun 11, 2001 07:05 PM
Mark305TBI
Jan 28, 2001 11:20 PM
