anyone used holley commander950 with 700r4
Old Apr 15, 2007 | 06:53 PM
dharrison's Avatar
Car: 1968 chevy truck, 85 z/28
Engine: 355, 355
Transmission: 700r4, 350turbo
the holley commander950 system does not include VSS and TCC and fourth gear controls like on the stock 730 ECM. how do you get around this problem?
Old Apr 16, 2007 | 12:07 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: anyone used holley commander950 with 700r4
Stay with the '7730? There are a couple of methods to control the TCC w/o an ECM. Some wire the 4th gear switch to activate the TCC. Others use a vacuum switch sometimes with the 4th gear switch. GM actually set up vehicles in this manner. Early Canadian 3rd gens included.
Try a search on the transmission board, there have been several discussions setting this up.
RBob.
Old Apr 16, 2007 | 12:42 PM
cgtms's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 5.7L TPI
Transmission: TCI 700R-4
Axle/Gears: 3.24
Working with the Commander 950 is nice. Easy to tune and you an tune real time.
We have done several after market EFI systems with 700R4. We use the B&M lockup kit under Summit Racing part number BMM-70244. It cost $164, but it works very well. TCI has one for around $80, but we have had issues with that kit. That kit also requires dropping you transmission pan to install the harness.
Hope this helps.
Old Apr 16, 2007 | 05:02 PM
dharrison's Avatar
Engine: 355, 355
i thinkin about using megasquirt now. i can still use the 730 ecm with it.
Royal_Z
Sep 30, 2015 08:45 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
dusterbd
Sep 29, 2015 08:40 AM
6998poncho
Sep 25, 2015 02:56 PM
