How much distributor play is ok? Accel Dual sync
Old Jun 24, 2007 | 11:50 PM
388's Avatar
388
Car: oldsmobile
Engine: 3.88
Transmission: yes
Axle/Gears: yes it has axles
How much rotor movement is ok? WHen i had the cap off I can move the rotor counter/clockwise 5-8 mm or so. I would have thought the rotor should not be moving at all.
I posted above at steady throttle my a/f is jumping around. im thinking perhaps play in the dist gears or rotor movement is causing timing to jump around ??
Old Jun 25, 2007 | 01:48 AM
bodie's Avatar
Re: How much distributor play is ok? Accel Dual sync
you should have some movement as the dis gear tries to turn into the cam gear,
if your trying to check shaft play , hold the rotor still and try to move the rotor front to back and side to side,
if you worried about dis gear wearing, just pull the dis out and visually check,
you already have the cap off
Hotrodboba400
Dec 10, 2019 07:07 PM
jer4251
Sep 27, 2015 09:52 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
