need help..code 44
Old Jun 26, 2007 | 09:07 AM
vingta1989's Avatar
Car: 1989 GTA CONVERTIBLE
Engine: 355 tpi
Transmission: ART CARR 700 R4
Axle/Gears: 3.70
need help..code 44
hi need some help with an intermitent code 44 ..after abut 15 mins of driving it comes on and the car misses a bit but wil clear up around 2500 rpm..cruise along at 2500 for 15 mins light goes out.then .on and off etc ...im running a 383 mini ram..dart pro 1 heads..11 to1..580 comp cam..1.6 rockres..ford motor sport 30lb injectors.... msd dist.. descreened maf..3800 stahl art carr 700r4 and 373 plus my in take pump with an inline pump..and i also get weird crackling or slight snapping sound from the exhaust at cruising speeds really cant hear it under full throttle..the exhaust is edelbrock shorties in a real dual exhaust stepped 2/12 then to 3 with no cats and magnaflow mufflers..car is an 89 gta stock ecm and a prom by tpis..any help greatly appreciated
Old Jun 28, 2007 | 08:02 AM
vingta1989's Avatar
Engine: 355 tpi
Axle/Gears: 3.70
Re: need help..code 44
any ideas ..my fuel pressure is at 50..
Old Jun 28, 2007 | 11:06 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Code 44 is O2 sensor lean, which fits with your description of the missing. By the sounds of your post the tune needs to be better. There are areas where not enough fuel is being delivered. Have you data logged and checked the BLM values along with the injector PW? That would help in knowing what is going on.
RBob.
Old Jun 28, 2007 | 11:53 AM
vingta1989's Avatar
Engine: 355 tpi
Axle/Gears: 3.70
thanks for the reply..i really am not to familiar with that although i have been reading a bunch on the entire subject..would it matter if the chip was cut for 24 and i upgraded to 30lb /hr injectors and did not change the chip..its from tpis..do you know of a good place to get a chip cut/ thanks again
Old Jul 2, 2007 | 08:01 AM
vingta1989's Avatar
Engine: 355 tpi
Axle/Gears: 3.70
all set ... thanks for the help
Old Sep 8, 2009 | 09:11 PM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
nevermind didnt see how old the post is.
