Is there a difference...
Old Jul 9, 2007 | 06:11 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
...between auto and manual PROM programs? My idle speed has been screwy since I swapped transmissions, and I would like to know if there really is a difference in the fuel curves. Or do I just need to see if putting in a new fuel filter and air box section will help? BTW, I have a 6 with the 302 ECM using either the HNR or APFR codes, they both do the same thing...
:edit: On the same note, I also need to know if there is any really hard work involved in swapping my MAF system for a MAP system from a 91 V6, such as repinning the C207 connector and the connector on the firewall near the steering column. I can get the harness and ECM from the 91 V6 (it's also a bird).
Old Jul 10, 2007 | 03:27 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: Is there a difference...
there is a difference between auto & standard trans chips.
it has to do with when the ECM returns to idle vs vehicle speed, & also i believe base idle. speed. there may also be other differences such as the spark tables.
i can't help on the maf to SD swap, sorry.
Old Jul 10, 2007 | 06:18 PM
Engine: 2.7L V6
Axle/Gears: 4.41
If that's the case, can someone give me a P/N or broadcast code for a PROM for a 302 ECM with the T5? Or, even better, if someone happens to have one kicking around they would like to get rid of, I'll take it off of you...
Old Jul 10, 2007 | 11:27 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
I have a 7302 for 2.8 V6 5
$35 Shipped (This includes entire ECM and MEMCAL)
Old Jul 11, 2007 | 05:08 PM
Engine: 2.7L V6
Axle/Gears: 4.41
PM me with the details, plz...
Or, better yet, since, for some reason, TGO isn't sending me notification emails, email me at maverickh1_l@yahoo.com.
Old Jul 19, 2007 | 02:03 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Still looking for that 2.8/T5 PROM/ECM. Bump!
Old Jul 19, 2007 | 09:01 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
I have one.
Out of a 1986 firebird.
Old Jul 19, 2007 | 09:38 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Shoot me an email at the above addy...
