Has anyone used this ALDL cable?
Car: 91 Trans Am
Engine: 355 l98 mini ram
Axle/Gears: stock10 bolt 3:23 gears
http://www.aldlcable.com/sc/details.asp?item=aldlobd1 What do you think?
Also what do you guys use around here, Datamaster or Freescan?
Re: Has anyone used this ALDL cable?
Board newbie & new to computer scan tools (deciding to move beyond the paper clip):
I have an '88 Formula 350 (8192 baud I think). Recently bought the USB cable (aldlobd1u) from aldlcable.com. Can't connect using DataMaster, and their ALDLTEST program errors out too. Have tried all the jumper positions on the cable. Windows recognizes the cable, knows when it's plugged/unplugged; the car knows when I have pins A & B jumpered on the cable, because the SES flashes code 12.
What's the right setup to use this combo? Or did I make a bad choice & need to get new stuff???!!!!!
Thanks for any info..........
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
dont really know what you have there.
however i got hung up trying to connect to the aldl because in the options menu of tunerpro it was set to the wrong com port. On my laptop the com port for the usb connection is com 6 and it comes defaulted to 1.
that and you need a .ads file (Definition file) to be able to do a scan
thats my only idea
thats my only idea
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
how do you get the .ads (definition) file for tunerpro?
Z28/ZR1
Oct 23, 2015 01:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
