TPS, MAT....what else?
Old Nov 3, 2007 | 03:13 PM
nomad88z's Avatar
So I plan on swapping in a TPI for my 88 TBI utlizing an EBL with my TBI ECM (BobR from dynamicefi.com says it will work).
I know that I need to add in the 6 extra injectors, and that the TPS and MAT need to be modified, but what other sensors do I need to add into the harness to make this work?
Also, if I do need more sensors for the TPI, how would i hook it into the TBI Harness with the TBI ECM and EBL?
thanks for any input.
Old Nov 23, 2007 | 11:58 AM
Scout's Avatar
Car: '64 Scout
Axle/Gears: HP 60 front, Eaton HO72 rear, 5.13
Re: TPS, MAT....what else?
I'm doing this myself. I have an 87 305 with tpi and a 7747 ecm. I moved a few pins in the connector and added a MAP sensor. It runs, but the truck isn't finished so I don't really know how well it runs. (can't drive it)
http://www.youtube.com/watch?v=-fNfa0DvL8I
The 87 harness is batch fire, so I didn't have to do anything about the injectors. I also added a MAP sensor. I used an existing port on the passenger side of the manifold near the distributor, and spliced into the TPS wires for the 5v and ground.
92camaro350cci
Oct 14, 2015 09:29 AM
Fred SS
Oct 12, 2015 11:27 AM
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
