help w no start want to test tbi
Old Jan 17, 2008 | 07:52 PM
buzzman1's Avatar
Car: 90 formula
Engine: 305 carb
Axle/Gears: auburn 3.73 posi
thanks for the help...have a 305 tbi 1990 and have crank no start.
have changed ignition module and new coil..wanted to test the voltage or pulse to the injectors to see if anything is up w/the ecm.any help is great.
thanks,
buzzman
Old Jan 18, 2008 | 08:07 AM
TT 68's Avatar
Re: help w no start want to test tbi
Make sure you have spark at the plugs first. I had the plug wire from the distributor to the coil come apart at one end and cause the car to not start.
Next I would install a fuel pressure test port fitting at the back of the throttle body and make sure you have fuel pressure.
92camaroJoe
Jul 29, 2023 07:57 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Jae992
Aug 27, 2015 09:07 AM
92camaroJoe
Aug 13, 2015 06:07 AM
