Differences between OBD-I and II
Old Apr 4, 2008 | 04:46 PM
camaro_guy24's Avatar
Car: 91 Firebird w/ L03
Engine: LT-1 Swap still in the works
Axle/Gears: 10 bolt w/ 2.73 (Needs 3.42 w/posi)
I need someone to tell me what the mechanical differences are between OBD-I and II i.e., components, differences of components from donor cars (f-body and b-body). thanx
Old Apr 5, 2008 | 07:59 PM
Re: Differences between OBD-I and II
somebody has to know what i need to know
Old Apr 6, 2008 | 02:49 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
OBD2 monitors a lot more than OBD1 does.
this isn't a complete list.
just off the top of my head, cats, evap system, how long it takes the engine to warm up, any other modules in the car, it controls shifts if it has an auto trans, the A/C clutch. depending on the OBD2 system, it may also control individual ignition coils.
on many vehicles the instrument cluster gets its signals from the PCM for MPH, RPM, temp & other things.
Old Apr 6, 2008 | 11:50 PM
923.4v6's Avatar
Car: 92 Camaro RS
Engine: 3.4/3500 hybrid
Transmission: 5-speed
can you change one over to OBD-II
Old Apr 7, 2008 | 08:22 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Youd have to convert over to a 96+ PCM + hardware/wire harness from a vehicle with a similar engine to what you currently have.
Old May 24, 2008 | 08:20 AM
S10Wildside's Avatar
Yes...
Distributor System: https://www.thirdgen.org/forums/tpi/...-opinions.html
...or...
Distributor-Less System: https://www.thirdgen.org/forums/dfi-...olled-gen.html
69GTOby
Apr 18, 2016 02:34 PM
BAMiller
Sep 14, 2015 06:38 PM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
