Open loop selection???
Old Jun 5, 2008 | 08:22 PM
hjcoupe's Avatar
Hi all,
I'm currently running tunerproRT with an Ostrich 2.0 in my GM 5.0lt V8 (oz engine) and wanted to try tuning in open loop (no cats)but for the life of me i can not find the flag or constant like it's easily seen in the 165 and $6E.
Would anyone be able to point me in the right direction of where to disable closed-loop and how to adjust PE.
It is a SD setup similar to your 165 ECU.
Thanks for any help...mario
This is my set up:
File Type: zip
File Type: zip
Old Jun 9, 2008 | 04:11 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: Open loop selection???
I may not be correct, but I don't think there is a flag to turn CL on or off. Instead, you adjust the CL temperature to something way high, so it never goes into CL mode. There should be a setting somewhere for the CL temperature, I think stock is something like 110 degrees. Someone correct me if I'm wrong though, I'm not 100% sure.
Old Jun 9, 2008 | 06:06 AM
hjcoupe's Avatar
Thanks Ward,in item find there are about 10 IAC closed loop parameters and 2 flags...KOPTFLG3 and 4 and thats about it,but cant put my finger on it.
Hoping someone could D/L my bin and Def and see what they can make of it.
Thanks again Ward...
Mario
Pac J
May 17, 2020 10:44 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
luvofjah
Sep 26, 2015 08:28 PM
Nick McCardle
Sep 10, 2015 08:36 PM
