Need a bin file for a '91 3.1 auto please!
Car: 3
Engine: inboard
Transmission: underfloor
I need a bin file to allow tunerpro to connect, does anyone have one? I checked with moates and they don't have one.
Car: check
Engine: check
Transmission: check
Re: Need a bin file for a '91 3.1 auto please!
You need AZTY, it is on various sites on the 'net. A Google will bring up locations to get it.
RBob.
RBob.
Car: 3
Engine: inboard
Thanks RBob! Are there any more search terms I can put in? I tried just typing AZTY into a Google search, but and got all kinds of hits for people's MySpace pages.
Car: check
Engine: check
Transmission: check
I used this:
+AZTY +ECM +Camaro
Then:
http://www.eecis.udel.edu/~davis/z28/index.html
http://www.diy-efi.org/gmecm/ecm_info/1227730/
RBob.
+AZTY +ECM +Camaro
Then:
RBob.
Car: 3
Engine: inboard
Thanks RBob- I found a bin for a '92 Camaro V6 with auto and SRS on the davis site- I saved it to my desktop.
NOW- when I open up Tunerpro, I go to "tools", select "ALDL Datalogging", select "choose preferrences" , it either allows me to select one in the program or hit "browse" and I do this, and select "Desktop", the problem is, it does not show me the entire contents of the desktop where I have the bin I downloded, so I can't select it and input it in to Tunerpro.
I will post this on the Tunerpro message board, once again, I am sure it is something in computereze I am not schooled it. But I am getting there one babystep at a time.
Car: 3
Engine: inboard
UPDATE- turns out it is an .ads file I need, so back to the search!
I did however get the laptop and Tunerpro to work on a bud's '87 GTA I am storing for him, the TUnerpro has the .ads for the 165ecm with 160 baud rate in it, so I selected that under preferences and it all talked to each other.
I will need to learn how to save logs and snapshots for sure- I work on diesels for a living and can do this with Caterpillar software, so I am sure once l learn all the terminology I will be able to do it too. I'll be spouting the lingo I see here about bin files and hex code with the rest of them one day.
