How do you know if your ECM is TBI or TPI?
Old Sep 16, 2008 | 11:01 AM
amichals's Avatar
They both look the same and I got one from somebody who says its for a 90-92 305 TPI. How can I be sure. The only thing the box says is;
REMANUFACTURED BY GM CORP.
SERVICE NO. 16196344
Then there is a bar code with the following number underneath it;
*866344WZ33010418*
Other than that. it has 2 black plug outlets and one yellow plug outlet.
Old Sep 16, 2008 | 12:42 PM
sid rs91's Avatar
Car: 91 RS TBI 91 Z28 TPI
Transmission: wc T5
Re: How do you know if your ECM is TBI or TPI?
It is a 90/92 TPI ecu.
Do a search on 16196344 for more info.
Old Sep 18, 2008 | 12:38 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
*866344WZ33010418*
Make sure that you unplug your eprom and put in new ecu.
That same ecu was in lots of other un-related TPI cars, so the eprom will be different.
You can also use 1227730 ecu, but again, exchange the eprom inside.
evilstuie
Jan 9, 2020 08:29 PM
Jae992
Aug 27, 2015 09:07 AM
Sanjay
Aug 12, 2015 03:41 PM
BOOT77
Aug 10, 2015 12:20 PM
marcusaw
Aug 10, 2015 08:13 AM
