Injector pulse miss.
Old Oct 17, 2008 | 06:00 PM
Chevhead89's Avatar
91 speed denstiy TPI. well it only happens occasionaly. cold, hot dont matter, everyone once in awhile itll occasionaly just miss. and then sometimes the whole pass. bank will just lose injector pulse. nothing at all. then itll all of a sudden just come back on, sometimes itll come right back on and somtimes its takin almost 10 minutes or so. im just lost and afraid to drive my truck any kind of distance. Thanks
Old Oct 18, 2008 | 08:04 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Injector pulse miss.
I would start with the injector fuses. Then check the injector feeds at the ECM. Sometime the pins get a little beat out and become intermittent.
On a stock '91 TPI all eight injectors are driven from the same driver in the ECM. However, each bank of 4 injectors has it's own wire from the ECM.
Then each bank of 4 injectors has it's own fuse.
RBob.
Old Oct 18, 2008 | 08:30 AM
Chevhead89's Avatar
ah i didnt know about the fuse. where is this thing at??
Old Oct 19, 2008 | 03:25 PM
Chevhead89's Avatar
damn thing did it to me again... any help on where that injector fuse is?
Old Oct 19, 2008 | 04:28 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Uh, in the fuse block. Drivers side under the dash.
RBob.
Old Oct 19, 2008 | 05:32 PM
Chevhead89's Avatar
o ok thats to easy... i figured itd be an inline or somethin hard to find. but if this dont work would ya say change the comp out?
92-Formula
Dec 12, 2015 10:34 PM
327IROC85
Sep 23, 2015 12:11 AM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
Ranbo108
Sep 9, 2015 12:20 PM
