350 1983 Z28
Old Oct 31, 2008 | 06:57 PM
tibbitt23451's Avatar
Car: 1991 Camaro RS
Engine: 406
Transmission: t5
Axle/Gears: 373
350 1983 Z28
I SWAPPED IN A 350 FROM A LG4, IM STILL USING THE CC CARB & DISTRIBUTOR. IT RUNS VERY ROUGH WITH THE ECM, BUT IF I UNPLUG THE ECM IT IDLES ALOT SMOOTHER. IT SEEMS LIKE WITH THE COMPUTER THERE IS A MISS. ANY HELP WOULD BE APPREICATED.
Old Nov 1, 2008 | 02:12 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: 350 1983 Z28
When you set the base timing did you unplug the bypass connector? What is it set at?
Old Nov 1, 2008 | 04:10 PM
Car: 1991 Camaro RS
Engine: 406
Transmission: t5
Axle/Gears: 373
Re: 350 1983 Z28
YES I UNPLUGGED THE ECM, SET TIMING AT 8. I JUST PUT IN A VACUUM ADVANCED HEI WITH TIMING AT 12. IF I STOMP THE GAS ROLLING AT 20 MPH IT WILL NOW BURN THE TIRES!
Old Nov 1, 2008 | 04:27 PM
89RsPower!'s Avatar
Re: 350 1983 Z28
you unplugged the ecm or the est bypass connector? If you're swapping to a non-cc dist you need to swap to a non-cc carb as well.. if the old 305 ran fine there's no reason it can't run fine with the 350, I'm betting its timing related.
Frozer!!!
Jan 19, 2024 04:55 PM
3tas4me
Sep 4, 2015 01:45 PM
Eric-86sc
Aug 24, 2015 09:01 PM
neekolzun
Aug 24, 2015 04:59 PM
Dan's 83z28
Exterior Parts Wanted
Aug 20, 2015 02:16 AM
